What do I need? (Tubes and 2 channel audio) (1 Viewer)
Howard Williams
I have a set of Klipschorns. What else do I need in order to experience and enjoy 2 (or 2.1)channel audio via tubes? I'm willing to spend up around, A) $1,000 B)$2,000. I listen to mostly R&B, Jazz, a little Pop, a little classical and even a little Rap. My Khorns have great bass but I really like the added bass given by my SVS 16-46PCi subwoofer and I'd like to incorporate it into my music system. I understand that everyone tastes are different and that there is nothing that everyone likes, so what I'd like are a few of the more popular pieces of equipment I need.
Thanxxx in advance.
Kevin T
hmmmm....sounds like a tube integrated amp is needed. i can't think of a tube integrated off hand with a sub out. you might wanna check on audiogon and the net for:
cary sli-50 or sli-80
jolida jd-302b or jd-502b
i prefer cary myself, but i'm a bit biased (pun intended).
kevin t
kevitra
The Cayin TA-30 is a highly regarded integrated tube amp. Do a google search and you will find plenty of reviews.
MusicLover95
