what do i need to play vcd's
Discussion in 'DVD' started by Ted Lee, Jan 27, 2004.
  1. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    hi all -
    my uncle gave me a vcd to check out. i pretty much knew my dvd player (samsung 931) wouldn't be able to play it, but i thought my computer could.
    however, when i pop in the vcd into my pc, it just opens up like a regular cd-rom would. i can view files, etc. but i couldn't get my pc to play it.
    so, do i need a special stand-alone player to view vcd's? is there special software?
    thx,
    ted
  2. Jesse Skeen
    Jesse Skeen Producer
    Apr 24, 1999
    4,322
    226
    Most DVD players can play them- did you try it?
    You do need a "player" software to play it on the computer- I have a couple VCDs that have it on the disc ready to install but some don't.
  3. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    hey jesse -
    yeah, i popped it in my stand-alone samsung ... it gave me a "no disc" error (or something like that).
    odd...maybe i'll try again....
  4. Ian_H
    Ian_H Supporting Actor
    Aug 6, 2001
    569
    Get the latest Media Player from Micro$oft. It plays VCDs.
    --Ian
  5. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    hi ian -
    i already have version 9. afaik, that's the most current right? i figure all i should have to do is pop in the vcd....correct?
    oh well, i'll try to play with it when i have a little more time.
    thx guys ...
  6. Christ Reynolds
    Christ Reynolds Producer
    May 6, 2002
    3,597
    CJ
    hey i get it. microsoft does well financially, and the dollar sign looks like a capital S. never seen that one before. anyway, you can download a vcd player from cnet and it should work fine. if you dont want to install anything else, you can play the disc with microsoft media player. open the mpegav folder on the disc and look for the .dat file, that is where the video is stored. play those with media player, and it will work fine.
    CJ
  7. Jonathan Dagmar
    Jonathan Dagmar Supporting Actor
    Dec 29, 2002
    723
    Im surprised your DVD pplayer won't work with VCDs, usually samsung players will play ANYTHING, literally.
  8. Edwin-S
    Edwin-S Producer
    Aug 20, 2000
    6,279
    415
    Is the disc an original or a copy? Sometimes copies will not play for some reason. I have made copies of my own CDs and they will not play in my Toshiba DVD player even though the player is CD capable. The copies will play in my old Pioneer laserdisc machine.
  9. Ian_H
    Aug 6, 2001
    569
    On the tool bar for Media Player goto PLAY then in the menu should be a line that says DVD (if you have a DVD-rom installed), VCD, or CD AUDIO then gives an arrow to point it to which ever drive you need.
    --Ian
