What do i need to connect xbox & ps2 to hdtv???
Discussion in 'Archived Threads 2001-2004' started by nate n, Jan 23, 2002.
  1. nate n
    nate n Stunt Coordinator
    Jan 22, 2002
    97
    I just got a panasonic 34wx50. What do i need to connect the xbox and ps2 to the component video outputs in the hdtv? I know this sounds like a dumb question, but i am very to new to the home theater world. Also, i know the ps2 has an optical output, but i cant seem to find the xbox's optical cable output. Thanks.!!!!
  2. ScottH
    ScottH Producer
    Jan 2, 2001
    3,173
    105
    4,110
    Scott Hanson
    To hook up the XBox for HD, you will need the High Definition A/V Pack (http://www.ebgames.com/ebx/categorie...p?pf_id=209496) as well as a TV that accepts component inputs. This A/V Pack also has the optical output on it. For some reason it's not on the console itself (just another way to get your money I guess). I think Monster makes component XBox cables as well, but they're about 3 times the price.
    As far as I know, the PS2 games are not High Definition and never will be. For better video quality though, it's still a good idea to hook it up via component video. You'd have to buy those cables separately as well.
