What damages a driver?
Discussion in 'Archived Threads 2001-2004' started by PaulDF, Oct 2, 2002.
  1. PaulDF
    PaulDF Second Unit
    May 17, 2002
    354
    Out of curiosity, what are the most common causes of driver damage? Bottomimg out, overexcursion, etc. Does unloading or bottoming out damage anything or is there built in protection for this? I am a little worried about unloading when I build my tempest...
  2. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    I wouldn't worry,
    What would damage a driver is extended bottoming out or perhaps pumping too much power into it for long periods of time. I've bottomed out my tempest on occasion when playing with test tones but I never notice it happen during movies. At worst, the bass gets a little distorted sounding but not much more.
    Other ways of damaging it would be to kick it in, or have it sit outside too long so the foam surrounds decay.
  3. PaulDF
    PaulDF Second Unit
    May 17, 2002
    354
    Thanks Chris, Makes me feel better.
  4. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    His mother-in-law in the back seat. [​IMG]
  5. Thanks Hank, makes me feel better [​IMG]
  6. tom_furman
    tom_furman Stunt Coordinator
    Sep 6, 2000
    174
    This is gonna sound retarded but what exactly does a sub bottoming out sound like? Ive never heard anything weird coming from my tempest so i dont think i've ever done it [​IMG]
  7. Hank Frankenberg
    Oct 13, 1998
    2,573
    Like a mother-in-law plopping down in a dining chair[​IMG]
    Somebody stop me!
  8. sounds like ...the coil hitting the motor [​IMG]
    it is a sharp thud type of sound. I am trying to think of another sound that is like it, but I can't. You WILL know it when you hear it. If you haven't, then good [​IMG]
  9. Chris_Campbell
    Chris_Campbell Stunt Coordinator
    Mar 6, 2000
    68
    The most damaging thing you can do to a speaker is to amplify it with a clipped signal. When a solid state amplifier in effect "tries to hard" and is pushed to it's very limits, it will no longer produce a smooth sine-wave type signal. Instead, the tops of the wave will be chopped flat, or "clipped off". When this clipped signal is fed to the driver, it makes the driver try to move discontinuously, and can severely damage it. This is why you will hear many experts say that underpowering a speaker is actually more dangerous than overpowering it. Because traditionally when your amplifier cannot provide much power, you will drive it to clipping quicker, and it will damage the speaker.
  10. to add: when the sine waves are clipped, you are effectively sending a continuous DC signal over the flat part of the voice coil. Not only does this sound bad (often gets mistaken for bottoming out), but the coil get heated up a lot more and that is why it is so bad.
  11. tom_furman
    Sep 6, 2000
    174
    The only thump i've ever felt was when i plugged in my amp before i turned on my receiver. WHUUMMMP! The concussion form the tempest almost knocked me over! [​IMG]
    now i have it plugged into a delayed circuit on my panamax
  12. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    Some truly low frequencies at high SPLs will make the subwoofer "fart" or pop. You'll know it when you hear it.
  13.
  14. Patrick Sun
    Jun 30, 1999
    38,749
    480
    9,110
    You mean: produce dog squeeze? [​IMG]
  15. oh nellie! there goes Pat off of his rocker!
  16. Patrick Sun
    Jun 30, 1999
    38,749
    480
    9,110
    I was just borrowing Hank's rocker.
  17. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    did somebody step on a duck?
  18. Pat, I didn't know hank had a rocker...I though he just had a walker [​IMG]
  19. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    See Hank! I ain't the only smartass around here! [​IMG]
  20. Hank Frankenberg
    Oct 13, 1998
    2,573
    Yep, but I blame YOU for spreading the disrespect!
