What crossover setting?
Kevin*H
My centre speaker and fronts have a frequency response of 38Hz - 20kHz
what would be the appropriate crossover setting on my receiver given that its crossover settings start at 40Hz
gene c
Bay area, Ca
Gene
It might help to know what sub and speaker brand you have but the standard response would be to set the size to "small" and the x-over to 80. But you could try 60 as well and see which sounds better to you. But I wouldn't go as low as 40 even with the 38hz spec. The disc you're playing probably isn't going to send very much that low to the center anyway. Thats what the sub and/or fronts are for. I sometimes have my Polk CSi5 center set to 60, mostly for music.
tvwatcher
