Arthur S
- Jul 2, 1999
Many people don't want to be able to locate their sub in the room because of leakage of higher frequency material. 80Hz is usually considered the max before you can locate the sub in the room. Others find 80Hz even too high.
Also, the crossovers built in to subwoofers often do not have a steep slope. In other words, if set for 80Hz, frequencies as high as 160Hz still bleed through at a reduced level. It is too bad that most sub testers do not measure the crossover slope, this is one area that can make a real audible difference.
Many disable the sub crossover and rely on the crossover built into their receiver. Unfortunately, most older receivers and most low price receivers have crossovers in the 100Hz to 120Hz range. My Kenwood VR 6070, a very serviceable unit, crosses over at 100Hz to the best of my knowledge. I prefer to have the subs crossover set as low as possible.
How do you have your subs crossover set?
Artie
Artie
