What country Sony XBR910 models are manufactured?
Discussion in 'Displays' started by Octavio, Dec 23, 2003.
  1. Octavio
    Octavio Stunt Coordinator
    Dec 23, 2003
    52
    Does somebody know where in the world Sony XBR910 models are manufactured?
  2. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Not off hand, but if you can get a look at the back of the set in a store there's a serial number sticker with the place of mfg printed on it. My CRT based Sony was built in the USA.
  3. Dwight Amato
    Dwight Amato Stunt Coordinator
    Nov 29, 1998
    193
    Just took a look at the back of my 34XBR910, it says made in Mexico.
    Why do you want to know?
  4. Octavio
    Dec 23, 2003
    52
    I am planning to buy model 30XBR910 and take it down to Chile.
    If the TV is made in Mexico, US, Canada or Europe I wouldn´t have to pay any custom duties. But if it were made in Asia 6% custom duty would apply.
    Thanks, Steve and Dwight, for your help.
    Octavio
  5. Steve Schaffer
    Apr 15, 1999
    3,756
    Octavio,
    Does Chile use the ntsc television broadcast standard or PAL? If it doesn't use ntsc the set will be useless there.
  6. Skip Hammerman
    Nov 30, 2001
    28
    Chile uses NTSC according to the web:
    world wide web.3dresearch.com/video/Countries2.html
    However, I am not sure about the electricity etc...
  7. Octavio
    Dec 23, 2003
    52
    Chile uses NTSC. Electricity is different than US since we use 220V instead of 120V. However a 500W converter (that costs here about US$25) is enough to make an american TV to work in Chile.
    One question to XBR910 users:
    When watching DVD´s using a progressive scan player, do you use DRC? Or is DRC for use with 480i sources only?
