What can I use to clean my screen protector?
Discussion in 'Displays' started by Joshua-E, Jun 24, 2003.
  1. Joshua-E
    Joshua-E Auditioning
    Jun 23, 2003
    2
    Is it safe to use Windex to clean my screen protector on my Toshiba HDTV?
  2. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    No windex!! ... it will take the/any tint coating off the screen!!
    Water or warm breath is best.
    Regards
  3. KurtJ
    KurtJ Stunt Coordinator
    Oct 14, 2002
    80
    I agree. My dealer told me to use a rag with a little water. If I can wring out any water, the rag is too wet.
  4. Mike I
    Mike I Supporting Actor
    Jan 20, 2000
    720
    Just use a soft slightly damp cloth..As mentioned previously never use windex...The ammonia in windex will discolor your screen
  5. James St
    James St Supporting Actor
    May 8, 1999
    959
    While browsing at Circuit City I saw Monster now makes a Screen cleaner. Has anyone tried this yet?
    [​IMG]
  6. WillieM
    WillieM Stunt Coordinator
    Jul 26, 2002
    60
    I find that a quart or two of warm water with just a little bit of liquid Spic & Span works nicely. Use a soft, lint-free rag - damp. Dry with the same type of rag (don't use paper towels! over time, this will scratch the surface). Just warm water is OK, but I find the soap helps cut any finger print oils or smoke residue with less elbow grease.
  7. JohnnyG
    JohnnyG Screenwriter
    Dec 18, 2000
    1,522
    I use camera lens cleaning spray and a microfiber cloth.
