What Calibration data do you use for the Radio Shack SPL meter??
Discussion in 'Archived Threads 2001-2004' started by Anthony_Gomez, Aug 5, 2002.
  1. As mentioned earler, I am writing a nice little program for you guys, and I am going to do a fitting on 1/6 and 1/12 octave analysis.
    BUT!..I need to know what Calibration data most of you people use.
    I assume most of you use http://members.tripod.com/~terrycthe...um/page11.html
    ..but that is only 1/3 octave. Anyone have anything better?
  2. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    That site didn't work.
    Well I forgot where I got this from but I use these correction values C weighted Slow response for test tones
    10Hz add 20
    12.5Hz add 16.5
    16Hz add 11.5
    20Hz add 7.5
    25Hz add 5
    31.5Hz add 3
    40Hz add 2.5
    50Hz add 1.5
    63Hz add 1.5
    80Hz add 1.5
    100Hz add 2
    125Hz add .5
    160Hz add -.5
    200Hz add -.5
    250Hz add +.5
    315Hz add -.5
    400Hz add 0
    500Hz add -.5
    630Hz add 0
    800Hz add 0
    1kHz add 0
    1.25kHz add 0
    1.6kHz add -.5
    2kHz add -1.5
    2.5kHz add -1.5
    3.15kHz add -1.5
    4kHz add -2
    5kHz add -2
    6.3kHz add -2
    8kHz add -2
    10kHz add -1
    12.5kHz add +.5
    16kHz add 0
    20kHz add +1
  3. That is the same file=)
    Thanks for confirming what I had thought.
  4. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,788
    498
    9,110
    Just wanted to add that there's a hump in the 4K-8K range (I tend to subtract 3db-4dB for 5K, 6.4K, 1dB for 8K, add 5dB for 10K, and then it gets wooly over 10K), and large sloping decline in the 8K-20K range for the RS SPL meter. I would not use any of the listed correction factors above 4KHz.
  5. Manuel Delaflor
    Manuel Delaflor Supporting Actor
    May 25, 2001
    657
    Anthony
    The SPL Meter is an invaluable tool, but I think is misused as a frequency response tool. The calibration files are taken as good, without any further research, just on a believe that "someone" has done it right.
    I prefer to stay with the readings of the SPLM and only take in to account their rated response, from 30 to 10,000Hz at +/-3 dB.
    As Patrick mentions, I have seen the hump too, and I guess the bass frequency response rolls off at a lower speed than the "correction" file allow us to think, but this is only a guess.
    I have a calibrated mic on order, and as soon as it arrives I will start to make tests with it comparing it to my SPLM. If you are still interested. contact me in a month or so.
  6. I am only doing this in the 10-100hz range for subwoofer duity.
    You will have the option of using Radioshace calibration data, your own calibration data, and no calibration data.
