What cables do I need -- BNC, DVI, Component, What??
Discussion in 'Accessories, Cables, and Remotes' started by Ben Mecham, Aug 1, 2004.
  1. Ben Mecham
    Ben Mecham Agent
    Jul 20, 2004
    25
    I'm getting ready to run cables in the wall for a new BenQ PE8700 projector. I have a Denon 3805, and I'm planning on using the component video switching and upconversion it offers to switch between the DVD player, Xbox, and HDTV tuner.
    My question is: what cables should I run to be future-proof and give me the ultimate in upgradeability, along with giving me the best performance with what I have?
    The projector has DVI-I, component RCA, and the 5 BNC connectors. Do I need the BNC ones to use the progressive scan of the DVD player? If so, then do I get a component RCA to BNC cable? And what type is best used for an HDTV box? Can I use progressive RCA into the receiver to switch? Will that still give me 1080i ?
    Sorry for all the questions, but as you can probably tell, I'm a little confused. HELP!!
    Ben
  2. Ed*Wheaton
    Ed*Wheaton Agent
    Feb 12, 2004
    33
    I was surfing the net the other day an was on the Radio Shack site.I was looking for a optical cable splitter or something that would let me plug more than one device via optical cable into my receiver which unfortunately has 1 optical input jack in the rear.I found a 4-way digital optical selector which allows 4 different devices to connect to your receiver at once,it has a switch that you turn to select whatever device you want to come through the receiver at that time.I f anyone has this product or knows about this product could you let me know it it's a good thing or not.The prod. # if anyone would to see it is 15-1586.The price is just $14.97 U.S.
    Ed
  3. Ben Mecham
    Ben Mecham Agent
    Jul 20, 2004
    25
    Also, I will probably be hooking a PC up to the projector in the near future... I assume DVI would be the best for that.
