What cable to use for dolby digital?
Discussion in 'Archived Threads 2001-2004' started by Alex_Hutton, Feb 28, 2002.
  1. Alex_Hutton
    Alex_Hutton Extra
    Feb 22, 2002
    20
    I heard it was fine to use a standard RCA cable which i did and it seems to be correct.
    I just want to make sure i wont cause any damage using such a cable for this.
    -Alex
  2. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    No damage, no. But I wonder if you will get the full 'bandwidth' that a digital signal needs. I'm not sure about the facts, someone will come along and clarify.
    - CM
  3. Jason Wilcox
    Jason Wilcox Supporting Actor
    Feb 21, 2002
    652
    i took a set of AR performance series audio cables and pulled them apart. i use one for digital coax (works fine for me) and one for my sub.
  4. Alf S
    Alf S Cinematographer
    Apr 23, 2000
    2,684
    440
    Alfie
    Yep...as long as it's a 75 ohm (yellow ended video cable) You will get a full fledged digital signal, no worries.
    Plus it will save you money as well!
    Alfer
  5. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Alex,
    BUt make sure you are coming out of the digital connection on the player into a digital connection on the receiver. Some people get confused because the jacks are the same as the analog ones.
    You can use an RCA cable without issue-- as long as your DVD player has a digital output on RCA jack and the receiver has a matching digital input.
    -V
