What brand of spades do you recommend for making my own speaker wires?
Discussion in 'Archived Threads 2001-2004' started by Gregg Hart, Mar 19, 2002.
  1. Gregg Hart
    Gregg Hart Stunt Coordinator
    Apr 15, 1999
    167
    I am considering making speaker cables using the Canare Star Quad line. Is there a de facto spade lug that people use? Also what is the best method of connecting them? Can I use crimps or do I need to solder them (which I have never done).
  2. Bill_Weinreich
    Bill_Weinreich Second Unit
    Sep 25, 2000
    317
    Gregg,
    Whats your $ limit. If its pretty high than I may suggest WBT. Expensive but great. I've seen them for $14 ea at partsexpress.com Check out their connectors section. They have a wide variety of solder and crimp type. IMHO crimping is best but solder will work. Just practice on some scrap wire.
    Good luck!
    Bill
  3. Lee Scoggins
    Lee Scoggins Producer
    Aug 30, 2001
    6,394
    Lee
    Gregg,
    Cardas in Bandon, Oregon makes some great ones and you can order direct from them. They are at www.cardas.com
    Lee
