What bit rate is the Dolby Digital output on the XBOX?
Discussion in 'Archived Threads 2001-2004' started by Justin Ward, Feb 12, 2003.
  1. Justin Ward
    Justin Ward Supporting Actor
    Jun 6, 2002
    673
    Is the bitrate of the Dolby Digital output on the XBOX limited to 448kb/s like DVD or can it output at the max data rate of 640 kb/s?
  2. Sean*O
    Sean*O Second Unit
    Jan 31, 2003
    251
    I have heard 640kbps.
  3. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    It's probably 640kbps.
    Imagine my surprise when a review of the nforce-based motherboards had a picture of a newer Yamaha receiver showing the bit-rate from the PC as 640kbps. As far as I know, the nforce audio has exactly the same silicon as the xbox chipset, even on the newest nforce2 chipsets.
    No wonder games sound so good!
  4. Bob_L
    Bob_L Supporting Actor
    May 19, 2001
    891
    2
    Bob Lindstrom
    I believe that the bit rate of DD5.1 is determined by the rate at which the original digital audio was compressed, NOT by the playback device
  5. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    One of the first Halo threads had a member that confirmed he was getting a 640kbps DD bitstream from the Xbox.
  6. JeffMuller
    JeffMuller Stunt Coordinator
    Apr 18, 2000
    183
  7. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    I believe Bob was referring to DVD playback. Naturally, it should passthrough the signal unaltered. Playing games, which involves real-time encoding, should be at 640kbps.
  8. Javier_Huerta
    Javier_Huerta Supporting Actor
    Mar 9, 2002
    619
    Hmmm. I have an old Yamaha receiver that can't do 640 Kb/s DD decoding. Something to think about. [​IMG]
