Nick Martin
- Mar 18, 2003
Since the only way I could prove it was to just use screenshots taken by others off of various websites, my suggestion for people (especially if they have the DVD to use as a comparison) was to just try it out once for themselves. I mean if it worked for me, I don't see how it wouldn't work for anyone else, because it's not like we're talking about different versions floating around.Originally Posted by cafink
Really? I wish you'd have said something about this before (or did I just miss it?), because that makes a big difference. I have not checked myself, but I most definitely recall, back when The Dark Knight was first released on Blu-ray, people reporting that this was not the case. The 2.39:1 version of the Imax scenes, they said, were not created by simply cropping an equal amount from the top and bottom of the 1.78:1 frame.
But if they are created that way, then it shouldn't present a problem for constant-height displays, right? The top and bottom portions of the image will be cropped off during the 1.78:1 Imax scenes (leaving the proper 2.39:1 framing), just as they would be during the rest of the movie when that area contains the black letterbox bars.
All I did was measure my TV screen when viewing the letterboxed portion of the Blu-ray so I could mark off where the borders would be when an IMAX scene came up, then popped the DVD on and looked at that. One particularly easy tell occurs late in the film, when Batman sets up that "string of sausages" trick of dangling the SWAT team officers over the side of the building. In the IMAX scene Batman's head is visible, but on the standard theatrical DVD his head is almost completely cropped, and I remember it looking that way at the movie theater as well. The focus is on the sliding officers on the floor, not Batman so it was easy to see why his head was cropped in that one brief shot. Masking out the scene on the Blu-ray showed the same thing the DVD did.
It didn't require anything fancy because I wasn't sitting down to watch it that way, I just wanted to measure it and compare.
