What are the best 6.1 demos? (1 Viewer)
Phil Tomaskovic
I know about Gladiator. Arre there any 6.1 Dolby discs out or just DTS? My old Sony dvd doesn't play any dts tracks.
One person in another thread saif JP3 but I don't see 6.1 mentioned on the case.
Jerry C
Grip
Star Wars: The Phantom Menace is DD-EX. There are others as well. Do a search on this forum. There's a thread that's updated periodically and lists DTS-Discrete, DTS-ES and DD-EX titles.
Dan Hitchman
For real 6.1, there is currently only DTS-ES Discrete 6.1
The best, by far, is The Haunting in DTS-ES Discrete. Blows the hell out of Phantom Menace.
DD EX is 5.1 channels with the back channel matrixed, as is the case with DTS-ES matrix.
Dan
MickB
JP3 is DTSes matrix like Terminator 3. Check out the Anchor Bay releases they have a lot of DTSex/DDex titles.
Kevin M
Kevin Ray
The Exorcist: the version you've never seen has a pretty dynamic Dolby Digital EX track (now if only I could remove the new ending).
Marty Lockstead
Hey Mick,
You mentioned T2 is DTS-ES matrix, but on my DTS-ES discrete capable Yamaha receiver, T2 shows on the display as being a separate rear-channel unto itself, hence it would appear to be discrete not matrixed. Only ES encoded DTS dvds show that rear center icon on the display.
francischen
