What are Discrete Remote Codes?
Discussion in 'Archived Threads 2001-2004' started by Stephan Bowman, Mar 12, 2003.
  1. Stephan Bowman
    Stephan Bowman Auditioning
    Mar 6, 2003
    6
    Hello,
    I'm excitedly awaiting the arrival of my MX-500 (which I purchased after reading many posts on this forum extolling its virtures). I would like to get the most out of the remote that I can and I have been reading some recent post about discrete codes, but I only have a vague idea what they are. So, my questions are:
    1) What exactly are discrete codes, and
    2) how can they simplify my remoting?
  2. Jim Lenneman
    Jim Lenneman Stunt Coordinator
    Apr 7, 2000
    152
    A good example would be a discrete power on code. It only turns the TV on - if it's already on it does nothing. Discrete input codes (TV/Receiver) takes you directly to that input, you don't have to toggle through various inputs to get there.
    It simplifies your remote by preventing your gear from getting out of sync. I.e. turning a piece of gear off (in a macro) when you didn't mean to. Also the input discretes let you jump to say video 3 - regardles of where you currently are. You can therefore build a macro to say play a DVD and it'll always take you to the right input.
    Jim L
  3. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    congrats on your mx-500. i absolutely love mine!
    you should also visit the remotecentral.com website. they have a forum dedicated to just hometheatermaster remotes:
    http://www.remotecentral.com/cgi-bin...aster/list.cgi
    you'll find all sorts of good info about discrete codes, tips and tricks, etc.
  4. Stephan Bowman
    Mar 6, 2003
    6
    Thanks for the info guys.
    I went to Remote Central as you suggested and there was more information on discrete codes there than I could process in a lifetime. I then spent several hours chasing down discrete codes for my components. Although, the thought of buying another remote just to teach my 500 is a bit much. If my wife ever found out how much I spent on a remote I'd be a dead man (and here I am leaving evidence all over the internet).
    Steve
  5. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
  6. Stephan Bowman
    Mar 6, 2003
    6
    If I wasn't 100% satified then I suppose the only option would be to return it. [​IMG]
    Thanks Ted
  7. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Remember that the OneForAll 7 is only about $25 so we are not talking a lot of money.
  8. Stephan Bowman
    Mar 6, 2003
    6
    No $25 doesn't sound like much, but in Canada that price will be inflated substantially. Without having priced it out, I would guess that remote would go for just over $50 and then throw another %15 sales tax on that.
    Call me cheap, but all these little extras add up to a bunch of moolah.
    Steve
  9. Stephan Bowman
    Mar 6, 2003
    6
    Just priced out a One-for-all 8 at Radio Shack and they retail for $59.99 (Canadian).
  10. jeff_coil
    jeff_coil Stunt Coordinator
    Dec 3, 2002
    157
    Hello I just rcvd my MX-500 in the mail I bought the bundled package with the jp1 cable and the 8811 All for One. I must admit I started to do some surfing last night on the Jp1 stuff and WOW it is a bit over whelming and semi complicated at first glance! I was hoping it would have been a bit more intuitive which it may end up being after I dive in. [​IMG]
  11. MikeSRC
    MikeSRC Second Unit
    Jul 19, 2002
    369
    Before you get too overwhelmed by JP1, see if you can get all the discretes you need through One for All advanced codes. You may find that you don't need JP1 for now.
  12. steven pm
    steven pm Agent
    Mar 1, 2003
    35
    3 thumbs up for the MX-500! You can probably find a cheaper one-for-all remote and just get by on the known discrete codes. A 3 or 4 device remote is plenty. One neat tip I found at remotecentral.com is the 'trick' for getting Mitsubishi rptv discretes (power & inputs) from the original remote.
  13. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
    Stephan, I purchased an OFA 6017 (which is the CDN version of the US 6011/6012w) at WalMart in BC for 24.95 CDN. It does not do JP-1 (it will with some soldering and EEPROM Mods) but is certainly sufficient for published Discrete/Advanced codes. As steven said above, they have a 4 unit remote for about 16 bucks that should also handle the published codes.
    For more info about some OFA programming, check this link:
    http://www.hometheaterforum.com/htfo...42#post1417642
