what angle for spl?
Discussion in 'Archived Threads 2001-2004' started by shane_watson, Jul 21, 2002.
  1. shane_watson
    shane_watson Stunt Coordinator
    Jun 12, 2002
    125
    at what angle do most of you guys hold your spl meter i have heard straight up, 45 degree angle,horizontal facing center channel.which is the most accurate?
  2. Bill Kane
    Bill Kane Screenwriter
    Feb 5, 2001
    1,359
    shane, I'd say most just point it 45 degrees toward the ceiling from the listening position. But I think its just as important to keep the meter stable and your hands free by finding a camera tripod to put in the couch/chair with the meter at your ear level when seated. The RS SPL as you see comes with a camera body-type thread.
  3. Frank Zimkas
    Frank Zimkas Supporting Actor
    Mar 10, 2002
    888
    I believe the instructions that came with my Radio Shack meter says Vertical.
  4. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i agree with bill - it's more important to mount the spl with the tripod. your body blocking the sound will have more effect than the angle you hold the spl at will.
  5. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    agreed on the tripod approach. Hey Ted, that closing comment on your posts, is that from James Randi?
