What Amp to use for Whole House Sound?
Discussion in 'AV Receivers' started by Luke D, Sep 5, 2003.
  1. Luke D
    Luke D Agent
    Oct 7, 2002
    47
    I am working on renovating my friends house. We are running speaker wires to 10 different speakers in the house (2 speakers in five rooms). Each speaker set will have a volume knob mounted in the room where the speakers are. My question is do they sell a 10 channel amp? Or would I have to purchase two 5 channel amps?
  2. Bob Elliott
    Bob Elliott Agent
    Jul 1, 2003
    43
    I am doing the same thing. I am planning on running a two channel amp and using a 6 room speaker selector.
  3. Luke D
    Luke D Agent
    Oct 7, 2002
    47
    Bob,
    Do you think that a two channel amp will be enough to drive all those speakers? I would think that you would not have enough wattage unless you are only listening to two speakers at a time. I would like to run more then one room at a time so I think I need an amp for each channel.
    Thanks for your input!
  4. Steve_Corrick
    Steve_Corrick Stunt Coordinator
    Feb 16, 2002
    91
    Multi zone A/V distribution system. Niles
  5. Rich X
    Rich X Stunt Coordinator
    Jun 18, 2002
    115
  6. Luke D
    Luke D Agent
    Oct 7, 2002
    47
    Rich,
    That sounds exactly like we would like to set up. I did not know that a 2 channel amp would be ok. What is the model of the xantech connecting block? I will have to look into the Impedance matching volume controls a little more. What volume control do you use?
    Thanks a lot for your help
  7. Rich X
    Jun 18, 2002
    115
    Crutchfield.com has a lot of good info and articles about this stuff. Check out this article:
    http://www.crutchfieldadvisor.com/S-...oom_power.html
    I cannot remember the model of the connecting block, but I think you can find them on partsexpress.com. Partsexpress might not have xantech, but they should have at least a dayton model.
    I have both Niles and SpeakerCraft volume controls. They both work well.
