What amp to drive a Tempest?
Discussion in 'Home Theater Projects' started by James~P, Aug 14, 2003.
  1. James~P
    James~P Stunt Coordinator
    Aug 8, 2003
    226
    i'm building a Tempest based sonotube sub, what amp should i power it with? cheaper the better.
  2. Craig Woodhall
    Craig Woodhall Supporting Actor
    Jul 11, 1999
    590
    depends on the enclosure, and budget of course.
  3. Dave Milne
    Dave Milne Supporting Actor
    Jul 2, 2001
    568
    I think a number of people have had good results with the 250-watt PE plate amp (about $120) or the more-powerful Rhythmic (sp?) which is also still under $200, I believe. Plate amps are a bit of a pain to mount to a sonotube, but it can be done... or you can build a stand-alone box for the amp.
    A used stereo amp or even a receiver also works well, assuming your AV receiver or pre-pro has built in crossover. I'd look for at least 300 watts total. I'm currently running a second-hand Adcom 555 (600 watts bridged) for one of my subs (not a Tempest) that I picked up for $300.
  4. David Giesbrecht
    David Giesbrecht Second Unit
    May 28, 2001
    306
    Pro sound amps work well and can be had for fairly low bucks, A tempest can handle quite a bit of power so anything between 300-700 watts is good even for sealed alignments. Check out QSC amps at parts express an RMX 850 bridge into one Tempest would work well and have good headroom and $300 is a pretty attractive price.
  5. James~P
    Aug 8, 2003
    226
  6. David Giesbrecht
    May 28, 2001
    306
    That crown looks killer should work well.
    good luck
