DanielJW
Grip
- Apr 16, 2004
I was just wondering what all of your thoughts were on this projector versus the 4805 and, more particularly, the Optoma H31. It seems like the BenqPE5120 doesn't get nearly as much attention as the others, yet has many of the same features and even some advantages over the other two (DVI connection that doesn't need an adapter). Plus, it's nearly $300 cheaper than the 4805.
I realize that the 4805 has many more options for being adjusted, but to be honest, I'm not really going to be fiddling with the picture that much, and a plethora of options would confuse me, if anything. Also, the Benq is apparently quieter, according to ProjectorCentral's review, in addition to having a 3 year warranty.
Also, it seems to be more suited for my room. I'm only capable of throwing about a 10-12 image, and I read that this projector throws shorter, compared to the H31 and the 4805. Basically, I want a budget widescreen projector with decent lumens and contrast. Light and darkness has never really been an issue in my living space.
So, is this projector worth a look or not?
Dan
Dan
