wharfedale diamond owners (8.3)
Discussion in 'Speakers & Subwoofers' started by Alfie, Jun 30, 2003.
  1. Alfie
    Alfie Extra
    Mar 21, 2003
    19
    any ever put sand? how do you open the back port for sand filling? thanks how much sand should you put?
  2. Chad A
    Chad A Stunt Coordinator
    Oct 21, 2002
    113
    I've left mine alone for now.
    I might do this in the future if/when I get bored.
  3. Geoff L
    Geoff L Screenwriter
    Dec 9, 2000
    1,693
    There have been a couple threads dealing with Wharf speaks and the use of sand or shot. A quick search may bring them forth for a read...
    My personal experience is:
    I and others, find it's better to use lead shot as opposed to sand.
    Not as messy to work with, easier to load and (unload if necessary). A funnel generally works pretty well to load threw the small 1.5" fill hole in the (Emerald EM~MKIV line)...
    Is there a difference in SQ with a speaker loaded as opposed to unloaded with shot or sand, you will have to make that "personal SQ call". [​IMG]
    One thing is for sure, they will definitely be much heavier and more stable....This can be a good thing if you might have little ones...
    Regards
    Geoff
