Mike Nep
- Apr 12, 2002
I recently moved into a new/used home and the in wall multi room speaker configuration jacks are unlike anything I've seen before. What it looks like the previous owner/installer did was, inside the wall from the speaker wires to the wall jack, run a positive wire to the signal side of the rca and the negative to the ground part of the rca. So what you see on the connection side is what seems to be a single jack for each speaker. Has anyone with install experience ever done it or seen it connected this way?
