Mike Strassburg
- Nov 4, 2001
I'm currently using an AudioSource 12" sub with the built in 150W plate amp. I've replaced the driver with an MBAcoustics W128 which is a DVC car sub...alum/poly. It was inexpensive so I went with it, only $40 from a friend.
I'm happy with the bass it puts out (but will build a dual Tempest sonosub over the winter), but at low volume levels it makes a burbling/farting sound..for lack of a better term. It's quite annoying as you can hear it in the background during dialogue scenes. I've got my Denon 3802 crossed at 80mhz, and the plate amp the same. Do I need to cross it over lower as maybe it's tyring to play the higher frequencies? Any ideas???
http://www.mbacoustics.com/ look under New Products for pic
