Weird....missing .dll?
Discussion in 'Archived Threads 2001-2004' started by Eric Samonte, Dec 17, 2001.
  1. Eric Samonte
    Eric Samonte Screenwriter
    Mar 31, 1999
    1,318
    I was using Opera and when I exited out, Zonealarm was gone, a dll was missing from Outlook and McAfee was gone too. I then restarted and it seems the zonealarm.exe file is missing. I try to open Mcafee but it doesn't go through. It just reads but never opens it. I look for these exe files and they're gone. Is there a new bug around? I know I should've updated my virus defs. You guys have any advice on this? I have tried to re-install Zonealarm for starters and it installs. I shut down per its instructions then when it all has started up. But with the ZA set-up menu up, it never goes finishes it, and just stops and goes away.
  2. Jeff R.
    Jeff R. Stunt Coordinator
    May 31, 1999
    175
    A common thing that viruses due is once they get on a system, they will "disable" any security programs you may have. You will need to reinstall those programs to get them working again. Start with Mcafee and get the latest virus definitions and do a complete scan of your system.
  3. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    Did you happan to open any emails with attachments before this happened? It sounds like the Goner worm to me too.
    KJP
  4. Eric Samonte
    Mar 31, 1999
    1,318
    I guess I did..and it was a doc friend wiht an attachment. I should've known better...CRAP!
    Thanks guys.
