Weird cable, can I use it as speaker cable?
Discussion in 'Archived Threads 2001-2004' started by Chris Brown, Aug 15, 2002.
  1. Chris Brown
    Chris Brown Stunt Coordinator
    Aug 14, 2002
    178
    I picked up a huge reel of this strange cable. It looks similar to Cat-5. There are a total of 6 cables: 2 18guage, and 4 22guage. I was going to strip all 6 wires and go 1 18 and 2 22's in for positive, and same for negative.
    What "Guage" would I end up with? Is this method a bad idea?
  2. Joe Tilley
    Joe Tilley Supporting Actor
    Jan 1, 2002
    686
    Chris, if I'm thinking right 1 18awg & 2 22awg would be close to 14awg when combined. IMO I wouldn't recommend it but I don't see why you couldn't use it if you using a small system. But if you are using big speakers or a high power amp I would say not to.
    Just my .02
    Oh & by the way welcome to the forum[​IMG]
  3. Chris Brown
    Aug 14, 2002
    178
    The system i'm using now is kinda ackward. I'm using a Pioneer VSX-D811S with the front pre-outs going directly to the amp in (bypassing the the pre-amp) on an old Fisher receiver. Powering an old pair of JBL L150's as my mains.
    The wires I was using before were 20guage (!) and it didn't sound too bad. Do you think it would be worth it to invest in some monster cable or possibly some home-depot 12 guage?
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    32
    Katy, TX
    Wayne
  5. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Hi Chris.
    A thinner wire over a long run causes a "slant" in the sound. The higher frequences are reduced a lot, but the lower frequencies are not. But you still hear sound so many people think thin is fine.
    Several speaker sites recommend the following gauge based on length of run:
    1-10 ft: 16 ga
    11-20 ft: 14 ga
    20+ ft: 12 ga
    Most of us just buy a spool of 12 ga from places like www.partsexpress.com or Home Depot and use it everywhere.
    Hope this helps.
  6. Bobby T
    Bobby T Supporting Actor
    Mar 13, 2001
    583
    My local Lowes sells 12 ga. cheaper than Home Depot.
