ways to make sub hit harder?
Discussion in 'Archived Threads 2001-2004' started by Nate Nelson, Aug 2, 2002.
  1. Nate Nelson
    Nate Nelson Stunt Coordinator
    Mar 12, 2002
    93
    ya know what....nevermind [​IMG]
    sorry for wasting your time. If there is a mod out there that wants to get some more server space back, delete this thread.
  2. Bruce Chang
    Bruce Chang Second Unit
    May 10, 2002
    283
    turn the gains up
  3. Bill_D
    Bill_D Supporting Actor
    Dec 10, 2001
    755
    Put it in a corner if not already for free gain.
  4. steve nn
    steve nn Cinematographer
    Jan 12, 2002
    2,418
    I give mine a kick now and then just to let it know to be good and I all-ways send it to the corner.
  5. Greg Haynes
    Greg Haynes Supporting Actor
    Oct 22, 1998
    577
    Nate,
    What did you do to change your mind?
  6. Chas_T
    Chas_T Supporting Actor
    Jun 1, 2002
    758
    Nate..
    I don't know what sub you own, but I've found the largest factors for sub effect are placement, calibration, source material and room enviornment.
    I'm sure you covered your tracks here, but it took lots of tweaking and many hours to find the best placement for the most impact.
    However, the sub manufacturer has a large part in the play. So my experience tells me manufacturer, placement, source material and calibration between sub and bass settings on receiver/pre-pro.
    My .02
  7. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    If your system has a particularly large resonance in the room that you've placed it, which some people have described as being muddy, then working on identifying and taming that resonace may give you that 'je ne sais quoi' that you're looking for. Good question though even if you thought about retracting it.
  8. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
    " ways to make sub hit harder?"
    "ya know what....nevermind."
    TOO LATE!
    Drop it from a higher level. [​IMG]
  9. JohnSC
    JohnSC Stunt Coordinator
    Jan 12, 2002
    142
    One quick way, if you haven't already done so, is to use a Y cable and connect the sub-output to both L and R inputs on the sub. This should give you +3 db. Effectively, all it does is double the input level going to the sub.
  10. Greg Haynes
    Oct 22, 1998
    577
  11. Ned
    Ned Supporting Actor
    Feb 20, 2000
    838
    It will increase the volume by ~3db. It won't increase the sub's maximum volume capability.
  12. JohnSC
    Jan 12, 2002
    142
    Correct. This is not an increase to the sub's volume capability but it will give you the increase if all other things remain constant in the system.
  13. Greg Haynes
    Oct 22, 1998
    577
    Thanks John & Ned [​IMG]
    Learned something new today [​IMG]
