Wayne J's Veritas Crossover Question (1 Viewer)
aaron_d
I have a quick question on the crossover schematic for this speaker. The diagram for the tweeter crossover says the positive reciver input should go to the negative speaker input. Is this correct? I imagine it has something to do with the phase of the ribbon tweeter.
Patrick Sun
It means only the tweeter is connected in reverse polarity (out of phase) from the other 2 driver sections of the speaker after their filters are connected in place.
aaron_d
Thanks Patrick that is what i thought. I just wanted to make sure it wasn't a goof on the drawing.
Patrick Sun
While not able to see the acoustic response of the tweeter filter, it appears to be a 1st order, and the low pass on the midrange is a 3rd order, so it almost makes sense that you'd want to make sure the tweeter is in reverse polarity in relation to the midrange.
Vivacitythinks
