way to disable amp section of 3802? (1 Viewer)
Yoon Lee
Since I got Rotel power amp, my 3802 is acting as pre/pro only. But, its amp section is doing the job. Is there a way to disable amp section? I look through the manual, but couldn't find a switch for it.
Selden Ball
Selden
There's no switch because you don't need to turn them off.
As long as you don't connect a speaker to a particular output channel on the receiver, no current can flow through that section of the amplifier circuitry. Power = current x voltage. No current = no power.
I hope this clarifies things a little.
Jan H
Yoon,
just connect the Denon's preouts (using an interconnect) to the Rotel and the amp section of the receiver will be bypassed. JH
Yoon Lee
BTW, then, my receiver getting warm does not mean my receiver's power amp section in action?
Jan H
No, mine gets warm, too. Denons run warm even when the amp section is deactivated. Maybe you have it an enclosed area?
Mike_A
selden, there's still a bias current on the output transistors, which is what makes the amp get warm with nothing connected. depending on the amplifier class, this may be a significant amount.
as far as i know, there's no way to turn the amp off still. having the amp on shouldn't hurt anything, but it will waste electricity and generate heat.
Yoon Lee
So Mike, it's gonna use as much electricity as it was driving my speakers?
Kevin, I've got Rotel 1075.
Mike_A
Yoon, it won't use as much electricity (notice it doesn't get as hot), but it will use some (quite a bit most likely).
Bignatt
