Wavy Lines,
Discussion in 'Displays' started by GabeP, Feb 2, 2005.
  1. GabeP
    GabeP Stunt Coordinator
    Dec 11, 2004
    65
    when watching watching a movie on Sony XBR with dvd via component, we get these wavy lines going up and down, also, how do i know if its on progressive scan, no switch on the back or anything
  2. Phil Tomaskovic
    Phil Tomaskovic Supporting Actor
    May 8, 1999
    751
    3
    I think the progessive scan switch is usually on the back of the dvd player or it may be in a setup menu it may have.
    I don't think you need to set anything on the tv.
    Is it possible you have some interference on the electrical outlet or are your cables connected snugly? Are the wavy lines only when viewing the dvd?
  3. GabeP
    Dec 11, 2004
    65
    yeah
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    Wavey lines can mean alot of thing...
    The progressive switch on/off should be in one of your DVD Player system menus. Try it both ways, as I'm sure that set will provide it on the Component Video Inputs.
    Other culprits can be grounding issues, Electrical Interference, I've even seen Radio wave interference cause it.
    Only on DVD. so that helps narrow it down some at least.
  5. GabeP
    Dec 11, 2004
    65
    ok ill try in the menu, but last time i remeber there wasn't anything
  6. GabeP
    Dec 11, 2004
    65
    update, my dvd player is retarded, i cant even get the setup menu, whenever i put setup when its on but no dvd inside, it says setup on the dvd player but nothing happens to the screen. I have the govideo dual deck thing with dvd and vhs
  7. John S
    John S Producer
    Nov 4, 2003
    5,460
    Hmm, Ok, I have a ton of issues with most of the combo units, even some things like wavey lines. I'd replace it, DVD players are pretty cheap.
  8. GabeP
    Dec 11, 2004
    65
    yeah, im gonna plead to my dad to buy a new sony!!!! He'll probobly say yes to make me happy [​IMG]
  9. GabeP
    Dec 11, 2004
    65
    i didn't know this blinks lol [​IMG] i meant this then[​IMG]
