watts per channel?????
Discussion in 'AV Receivers' started by Sheldon-m, Jan 14, 2004.
  1. Sheldon-m
    Sheldon-m Stunt Coordinator
    Oct 22, 2003
    217
    How much of the sound is routed to the surrounds? I have a Onkyo 601 and it is 85W a channel. In my setup I can hear them(surr) but they are not like the mains or the center.
    it is like they are only getting half the watts per channel?
    what can i do? did do something wrong. Should the same i be getting 85w out of my surr? thanks
  2. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Did you set your system up with Avia/DVE/Sound & Vision. That is the best way to set things up.
    Depending on which mode you are listening in and what you are listening to(DVD,Cd's) will have an effect on how much sound goes to the rears.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    Yes, please provide more information...
    Like what sources are we talking about here?
    You Fronts and Center should surely be getting more content than the surrounds, butthey should all be equally loud. Pans from behind to in front should be seemless, on DD/DTS DVD's.
    Maybe give a specific source / title combo that you don't feel the surround is where it should be on.
  4. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,984
    6
    110
    The idea in 5.1 discrete is that all 5 channels receive full power to each speaker. DPL was the only thing that sent sound at half the bandwith to the surrounds. DPLII, Logic 7 I believe changes that. If you think you surrounds are to low, then use the test tones on the receiver to measure the sound from each speaker. Also note the level of each speaker on the receiver if it's displayed.
  5. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    Don't worry about watt numbers. There is usually never as much information sent to the rear channels on DVDs, therefore you will not hear as much coming from them. They will get as much power as the fronts if the DVD sends more information to them.
  6. Sheldon-m
    Oct 22, 2003
    217
    see thats the thing. i though that the receiver would send at least 50%to the fronts & 50% to the rears. i guess that is not the case. i just though since the speck say that there are 6 channels @ 85 watts. thats what it would produce.
  7. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    5,110
    Just because each channel gets the same amount of power doesn't mean it will get the same amount of sound.
    Power is a function of your equipment. Sound is largely a function of the source material, and most movie soundtracks concentrate their sound in the front. In fact, the most active speaker is usually the front center.
    M.
  8. John S
    John S Producer
    Nov 4, 2003
    5,460
    That is what it will produce.....
    But only when and if the surround sound audio engineer decides it should. Like on a Helicopter Fly over or something. Starts loud in the rears, pans to the fronts, then fades off as it gets further away.
    The front soundstage (Fronts, and Centers) produce the most sound, because after all you are looking forward.
    Go to Dolby's website, there is good detail there about how and why movies and surround sources are mixed the way they are.
  9. RobWil
    RobWil Supporting Actor
    Mar 17, 2003
    733
    And remember that the surrounds are just for effects. They aren't meant to receive the same sounds that are sent to the fronts.
