Eric_Connelly
- Nov 25, 1999
We've kicked around finishing our basement again, mostly for HT use.
We do have a high water table and run dual sumps. We're also on well water. The company that installed our water treatment system ran the backflush system into the sump crock.
This of course flooded the crock with rust waste...and clogged it....we've had 3 "floods" this past 2 years.
2 were from 2 dead sumps, overworked(thats been fixed)
The last one one sump clogged with rust. The other sump had another issue.
We were running about $100 in sump pumps alone on electricity. I installed 2 piggy back float switches which dropped our usage down to about $12 per month.
When the one sump died from rust of course the float switch got stuck on the overflow pipe....
So now all that has been resolved.
I watch the sumps monthly and hopefully will not have a problem.
Still we want to put in a HT in the basement. Its roughly 2000sq feet and the area we want to finish is about 18x20. We want to put in a subfloor.
In the event of another flood we'd like to seal the subfloor off. Worst case we've had 1-2 inches of water and very little in the area we want to finish.
If we could seal proof the sub floor and extra room area to about 3" then we wouldn't need to worry about another failure.
Is this possible? Would it work?
We do not have water problems from the walls, ever so I'm not worried about that too much.
