Warner Compression Problems?
Discussion in 'DVD' started by Patrick Mason, Mar 15, 2006.
  1. Patrick Mason
    Patrick Mason Stunt Coordinator
    Dec 1, 2005
    144
    28
    Los Angeles, CA
    Patrick
    Warner has long been considered a leader in DVD for a reason, and their transfers nearly always first-rate. Yet I feel their transfers on their most recent new release and catalogue titles have been suffering from some rather severe compression artifacting.
    I have noticed it in these titles off the top of my head:
    Good Night, And Good Luck.
    Harry Potter and the Goblet of Fire
    Lust For Life
    Network: 2 Disc Special Edition
    North Country
    I have not heard anyone else discussing this rather distressing decline in quality, yet both my high definition television (with a progressive scan DVD player and component inputs) and my Macintosh computer can both clearly display this issue.
    Am I alone here?
    Patrick
  2. Guido Bibra
    Guido Bibra Stunt Coordinator
    May 18, 2003
    82
    You're not the only one getting that impression! I've noticed some unusual compression artifacts on "Charlie and the Chocolate Factory" and "Corpse Bride". It's not shockingly bad and the masters are really good, but compared to discs from other studios it's noticeable. For instance, "Corpse Bride" was shot completely digital, but doesn't look as good on disc as its colleague "Wallace & Gromit", which was shot on film.
    I think this is an encoder problem, because both of these discs haver relatively high bitrates and still exhibit these artifacts. It may be just a technical problem, but maybe Warner is deliberately a bit sloppy with the compression so the future HD-releases look better...
  3. Patrick Mason
    Dec 1, 2005
    144
    28
    Los Angeles, CA
    Patrick
    Well at least someone out there is seeing this. I have also seen those two films on disc and they seemed to exhibit the same problems.
    I hope your HD-DVD conspiracy theory isn't true, but it's along the lines of what I've been thinking as well...
    Patrick
  4. Joseph Bolus
    Joseph Bolus Cinematographer
    Feb 4, 1999
    2,526
    249
    4,110
    I recently viewed my copy of the new Harry Potter DVD on my Infocus 4805 and can verify that the disc exhibited compression problems (especially during the first seven minutes). Again, it wasn't *terrible*, but it was noticeable. (It also seemed as though the contrast level wasn't consistent throughout the movie.)
    There is no doubt that a properly mastered HD version of the "Goblet of Fire" movie will blow this transfer away in a side-by-side comparsion, even on a relatively small 16:9 display.
    Warner better not be "dumbing-down" DVD transfers in order to make the HD versions look better or they could have a major consumer uprising on their hands!
  5. Guido Bibra
    May 18, 2003
    82
    Maybe this is really "only" an encoder issue. It doesn't look as if anything has been filtered out, the compression isn't just as invisible as it should be. Maybe we just got too sensitive, because studios like Dreamworks got so much better with their compression technique.
    The Dreamworks Animation DVDs all look terrific, and they usually have bitrates not over 6 mbit/s and squeeze extras plus movie on one DVD-9 without problems. Corpse Bride at 77 minutes uses ca 4,2 GB with an average bitrate of 7.39 mbit/s (brutto, there are four soundtracks at 448 kbit/s in there, but it still should be enough). Wallace & Gromit has 84 Minutes, uses only 3.9 GB with an average bitrate of 6.29 mbit/s (with two 5.1-tracks at 448 kbit/s and three 2.0-tracks at 192 kbit/s) and looks like a superbit disc!
    I'm not pointing fingers at Warner, but other studios are just better with their compression. Does anyone know who does the Authoring for Warner? I haven't seen any logos from Deluxe or other firms on their discs.
  6. PatH
    PatH Second Unit
    Apr 4, 2004
    325
    If any studio dumbs down standard dbd trasfers to push HD/Blu-Ray, how would you prove it?
    PatH
  7. Guido Bibra
    May 18, 2003
    82
    I knew I shouldn't have written that... I'm not accusing Warner of "dumbing down" the dvd transfers, that was just an observation - I don't believe the compression problems are intentional. Maybe there are discs from other studios which have the same problems, but I've only noticed this on the recent Warner discs. It's entirely possible that this isn't studio-related at all, but a problem of a certain authoring facility.
    Compared to some other quality issues this is really peanuts. Try watching a Warner disc from 1997, with a 130-minute-movie compressed onto one layer :).
  8. PatH
    PatH Second Unit
    Apr 4, 2004
    325
    Guido:
    I understood you weren't accusing them, but my question still stands. I don't think I'm a conspiracy nut, but the possibility you raised is valid, for any and every studio, if not now, then down the road.
    PatH
  9. Patrick Mason
    Dec 1, 2005
    144
    28
    Los Angeles, CA
    Patrick
    The thing that bothers me here is that these compression issues have been so severe and consistent throughout their entire crop of recent releases. Any dark areas of the screen are constantly plagued by terrible pixelation.
    What's distressing is that this is from Warner's, who have been providing the most wonderful transfers for years without these problems. I would hate to see their fantastic upcoming slate of movies continue with these issues, yet I have not seen any reviewers pointing out the problem in these releases.
    I'm afraid the studio may not be aware of the issue, and it would be great if somehow an awareness could be raised of the problem so that it can be fixed in future releases.
    Patrick
  10. Guido Bibra
    May 18, 2003
    82
    I just remembered where I've seen those compression artifacts before: on some Disney releases. I'm not actually a fan of Disney stuff, but I've noticed the same problems on "The Incredibles" and even some time ago on "Finding Nemo". I think it's the same macroblocking on some backgrounds and the pixelation in the dark areas, but then it could be unrelated. But it's not an entirely new phenomenon.
  11. Yumbo
    Yumbo Cinematographer
    Sep 13, 1999
    2,227
    I've viewed 1,2 and 5, and saw no problems on a 185" screen. They actually looked good.
  12. widescreenforever
    widescreenforever Stunt Coordinator
    Dec 28, 2004
    220
    arthurjulius
    I was watching on DVD the other day, my new addition to my library of Charlie Chaplins' 'City Lights'*.., This is a you know 1931 B/W near talkie ( some audio),, YET the Bitrate was a constant 10 through the dvd..!
    No wonder it looked so good.. a ten.., can you image?
    (*Warner Bros release from 2004 )
    most of my other dvd releases are 5.8 to 7.9 bitrates thru out.
  13. Andy_MT
    Andy_MT Second Unit
    Jun 23, 2001
    486
    yet another reason why i'm cutting back on dvd purchases. i'm fed up with all this type of nonsense (i.e. new releases with problems).
    if this issue (which i was surprised to see on corpse bride) is not known by the studio, then this does not bode well for HD. well after all, if they can't get SD-DVD right ...
  14. Guido Bibra
    May 18, 2003
    82
    I don't think the R1 Chaplins from Warner are a good example, because these were transcoded to NTSC from PAL masters. But that wasn't exactly the fault of Warner, because they only licensed these movies from MK2 France and that company only provided the restored PAL masters. But we're losing the theme of the thread here :).
    Absolutely wonderful encodings on Warner R1 discs are the new SE of Blazing Saddles, all of the Ultra-Resolution-Restorations... well, nearly all of their discs except the very recent ones. I haven't look at anything newer than "Charlie and the Chocolate Factory" and "Corpse Bride", but the new R1 Marple Boxset is on the way and I wonder how good the black-and-white photography will hold up.
  15. Ryan Wong
    Ryan Wong Stunt Coordinator
    Oct 6, 2002
    134
    I too noticed some compression artifact on Charlie and the Chocolate Factory. But I just watched Harry Potter and GOF last night, no issue at all. I think the first 7 minutes is intended to look gainy, which I don't really fancy.
    How about Polar Express? I noticed some compression issue there.
  16. Yumbo
    Sep 13, 1999
    2,227
    Sounds like a POSSIBLE decoding issue for some.
  17. dailW
    dailW Stunt Coordinator
    Oct 28, 2004
    222
    watched good night on tues.and was disapointed with the transfer same with the new harry potter.they are making universal look good
  18. JiM T
    JiM T Stunt Coordinator
    Apr 10, 1999
    212
    The "HD-DVD conspiracy theory" is admittedly the first thing that shot through my mind upon reading the first post in this thread. I hope, hope, hope, it's not true, as WB has been my favorite for a few years now. But that said, due to the high res formats coming along, I've already made a personal decision to slow down a bit on standard DVD purchases, particularly of new titles. A few years ago, "Good Night and Good Luck" and "History of Violence" woould've been instant blind buys. Now, I can't seem to get myself to spend the money. HOWEVER, I won't be able to resist the upcoming John Ford sets in June, and really really hope that those films, above anything else, are not in any way compromised.
  19. Mark Zimmer
    Mark Zimmer Producer
    Jun 30, 1997
    4,300
    40
    I wonder if it might be an encoder issue---they may have gotten in some new equipment that's causing this. I've noticed it primarily on discs that have 23 or 24 chapter stops (the new Miss Marples, Ten Little Indians being the most recent ones).
  20. Mark Lucas
    Mark Lucas Second Unit
    Aug 3, 2005
    497
    Maybe the companies that Warner uses for compression don't have a lot of time to spend on quality control.
