wanting big image with small throw?!?!
Discussion in 'Displays' started by richArm, Jan 4, 2005.
Thread Status:
Not open for further replies.
  1. richArm
    richArm Auditioning
    Jan 3, 2005
    8
    my room is only 12'3" or so. how large of an image can i get from the infocus 4805? another thead mentioned a pan ae700 with a great image at 120"s in size, might that be a good alternative.
  2. Paul-D
    Paul-D Stunt Coordinator
    Sep 15, 2004
    130
    For the 4805
    Depending on how exactly you place your pj, at 12'3" you can have anywhere from 78 - 94 inches. But if you're measuring wall to wall at 12'3" than you're pj will be shorter than 12'3" It'll probably be more around 11'6" which will give you screen size of 74-89 inches.
    Just go here and click on calculate your image size to get more info. I don't know anything about the pan.
    Good luck to you
  3. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Rich, let's keep all these questions in your larger, other thread here in Display Devices. Thanks. JB
Thread Status:
