Wanted: REALLY BRIGHT Sounding Speakers
Discussion in 'Speakers & Subwoofers' started by Arthur S, Jan 4, 2004.
  1. Arthur S
    Arthur S Cinematographer
    Jul 2, 1999
    2,568
    Getting pretty old here. Bought several pairs of speakers and they sound dull to me. I will probably pick up a ten band equalizer and see if I can pick up the highs enough to satisfy me.
    My mains are JBL L60T's with the first generation of JBL's titanium tweeters. In order to get a satisfying balance I have the treble tone control maxed to +10.
    The other thing that I would like to mention is that ever since I got a subwoofer, I have had to boost the highs. People might say "then you have your sub too loud". That may be the case, but I set it where I like it.
    As you have already realized I am not a purist. Maybe receivers sound better bypassing the tone controls, but without the tone controls the sound is just not satisfying.
    Thanks in advance for any ideas or recommendations.
    Artie
  2. DanaA
    DanaA Screenwriter
    Nov 21, 2001
    1,843
    You might audition the Klipsch reference speakers to see if they float your boat. For online companies, you might check out the Axioms.
  3. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    Yeah, check out Klipsch for sure. If you have the budget, check out some studio monitors as well. Many of these are considered very bright compared to the typcial home speaker. e.g. Mackie HR624 is what I have, and they are so bright I had to turn the treble tilt down 2 dB (there's flat, +2, -2). I hear stuff on these monitors that I never heard on home speakers.
    Also, generally speaking, metal domes will be brighter than soft domes for tweeters.
  4. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Not to be impolite, but you might want to look into a comprehensive hearing exam to determine if you've got signficant high frequency hearing loss.
  5. James W. Johnson
    James W. Johnson Screenwriter
    May 26, 2001
    1,055
    Most adults do..compared to children anyways.
  6. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    And usually men more so than women. It just sounded like this might be more than 'normal'.
  7. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    Why not a pair of hi-end, JBL pro speakers? You could EQ the heck out of the tweeter and be fine.
  8. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    Or just turn up the treble controll,most are centered at 10khz,and it won't cost you nothing. Try it out.
  9. David Barteaux
    David Barteaux Stunt Coordinator
    Jan 6, 2001
    179
    M&K?
  10. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    I second Chu, not to be rude but it cant hurt to have your hearing checked. You may not be able to hear frequencies above say 13KHz. Boosting the highs with EQ may make things worse.
  11. Robert AG
    Robert AG Stunt Coordinator
    Sep 27, 2003
    129
    Cerwin Vega should be bright enough, and loud to boot.
  12. Ryan T
    Ryan T Second Unit
    Sep 10, 2001
    406
    Klipsch are the brightest speakers i've ever heard in my entire life. To the point were they gave me a headache. You should check them out if you want REALLY bright speakers. Also some infinity speakers are really bright.
    Ryan
  13. James W. Johnson
    May 26, 2001
    1,055
    Klipsch are uncompressed and dynamic, you don't have to be deaf to enjoy them. [​IMG]
  14. Manuel Delaflor
    Manuel Delaflor Supporting Actor
    May 25, 2001
    657
    Klipsch, also, are not "bright" speakers per se. They are simply more revealing. Bright recordings do sound brighter on Klipsch, but audiophile grade recordings sound like they should, and not muddy, opaque or lifeless.
  15. Chris Quinn
    Chris Quinn Screenwriter
    Jan 12, 2003
    1,127
    Klipsch are bright.
  16. Shane Martin
    Shane Martin Producer
    Sep 26, 1999
    6,017
    Klipsch and Axiom are the top 2 I would recommend if you are looking for Ear-bleedingish bright.
  17. John-Tompkins
    John-Tompkins Second Unit
    Jan 21, 2003
    326
    Klipsh is a good choice for your preferences but also check out Martin Logans...when I auditoned (forget model number) they were REALLY REALLY revealing and ran me out of the room in short order.
  18. Michael Yung
    Michael Yung Stunt Coordinator
    Mar 15, 2001
    152
    Forget Klipsch, try Triangle, a French speaker manufacturer. Very dynamic and forward sounding and easy to drive too. If you find Triangle dull, then I would second the hearing check idea too.
  19. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Axioms are not excessively bright, IMO. Not nearly as much as Klipsch anyway.
    What is your other gear? While the speakers make the largest difference overall, all of your gear will play some small role in the sound of the system.
    How about your room? Carpeted? Large?
  20. Manuel Delaflor
    May 25, 2001
    657
    Chris:
    "Klipsch are bright"
    Thanks for sharing your thinking!! But
    NO
    Klipsch are not bright, the recordings you have listened in them ARE. [​IMG]
