Mark Larson
- Mar 3, 2002
I just got an old speaker from a friend of mine, with those adjustments for treble and mid on the speaker itself. I tried it out, and holy of holies, IT WORKS!! It says Acoustic studio monitor on the front, and has a sensitivity of 95 db/Watt.
Now, there are a few problems with that speaker, and i'd appreciate it if you guys could help me out with that...
1. The black finish is scratched on the top, probably from frat parties. Any ideas on what product i can use to clear out the scratches and polish the wood to make it look a bit better?
2. The tweeter doesn't work - it looks like a 3-way, with a small (cone! :frowning tweeter, a mid-range, and a 12" woofer. When i put my ear to the speaker, the sound is only coming out of the mid and the woof. I understand it is really bad to not have any highs, so what do you suggest i should do? The tweeter looks like a 2".
3. The woofer has to go - it is a Cerwin Vega 'Stealth' model, and i want to replace it with something nice ASAP. (A car woofer? )The only problem i foresee is that the driver may not be optimised for the cabinet. However, it already looks like a replacement, and the paper cone is getting tatty - it is grey and looks 'orrible. Should i try painting the current woofer over with something to give me better sound? I seem to remember some website giving advice on painting paper cones with a commonly-available solution to help with rigidity.
Thanks for reading this far!
Any ideas will be welcome!!
Mark
Mark
