Want to "dress up" my screen. Suggestions please!
Discussion in 'Home Theater Projects' started by Dan Brown, Sep 13, 2005.
  1. Dan Brown
    Dan Brown Auditioning
    Sep 6, 2004
    8
    I've got a Da-Lite 92" retractable screen and I want to make it look better, it seems so unfinished just hanging there. I'm leaning towards removing the screen and framing it or just hanging some drapes around it. I like the idea of framing it because it will get rid of the ripples.
    What are most of you doing?
    Dan
  2. David Noll
    David Noll Stunt Coordinator
    Aug 31, 2004
    228
    Dan,
    http://www.hometheaterforum.com/gall...g2_itemId=1102
    The black velvet-like black-out material around screen is on a 45 degree angle and trimmed in oak casing. The screen actually sits back about 6" from the screenwall. My screen is attached to metal channel which is also has velvet-like material on it, so it blends nicely.
    David
  3. Dan Brown
    Sep 6, 2004
    8
    That looks nice, David! Do you have a fixed screen already or did you have to mount that one?
  4. David Noll
    Aug 31, 2004
    228
    Dan,
    That Stewart screen is fixed, although it came unassembled and had to be put on the metal frame. I didn't get to help do the assembly.
    David
