TimForman
- Dec 4, 2002
You've probably reached the point where the speaker is distorting at it's resonance frequency causing a voltage peak. You're correct that the amp protection circuitry is kicking in. You're also correct that it's not designed to be run this way and that a box would help stabilize it.
