Want to Add 2 Channel Amp to System. Need Help.
Discussion in 'Archived Threads 2001-2004' started by Raffi A, Apr 11, 2002.
  1. Raffi A
    Raffi A Extra
    Mar 23, 2002
    16
    The following is my systems specs:
    Receiver: B&K AVR 305
    Fronts: Paradigm Ref Studio 60 v2
    Center: Paradigm Ref Studio CC
    Surrounds: Paradigm Ref Studio ADP
    Sub: Paradigm PW2200
    DVD: Sony 9000
    Speaker Cable: Audioquest
    I would like to add a 2 channel amp to my system to power the front Paradigm Ref 60's. Please Help!!!!
    Amp's I'm going to look into are:
    Rotel 1080
    Rotel 1090
    Anthem MCA 2
    Bryston
    B&K 2220
    In no particular order.
    I know the Bryston would probably kick the other amps asses but the price is well beyond the others. Any other advice on other 2 channel amps would be appreciated.
    Raffi
  2. Ron Reda
    Ron Reda Cinematographer
    Jul 27, 2001
    2,276
    2
    Raffi,
    What's your price range?
  3. Tony Meconiates
    Tony Meconiates Stunt Coordinator
    Jan 21, 2002
    188
    odyssey stratos
  4. Raffi A
    Raffi A Extra
    Mar 23, 2002
    16
    Forgot to mention, budget is $1500 - $2000.
  5. DavidSegelstein
    Feb 22, 2002
    20
  6. Justin Doring
    Justin Doring Screenwriter
    Jun 9, 1999
    1,467
    The Paradigms are not very particularly demanding speakers. I think your current B&K receiver is more than up to the task.
  7. Ron Reda
    Jul 27, 2001
    2,276
    2
    Damn, Tony beat me to it!!! [​IMG]
    I'd say Stratos all the way. Give Klaus a call and talk to him about your set up...he's quite the character and will give it to ya straight, no B. S.
  8. Mike Nep
    Mike Nep Stunt Coordinator
    Apr 12, 2002
    93
    Odyssey...that's all and that's it. You can even get a three channel for under 1500, well right around 1500 w/ cap upgrade. I've got studio 80's. Look at posts everywhere and you can't really find anything bad said about it. Bryston is excellent however.
  9. Mike Matheson
    Mike Matheson Second Unit
    Jul 15, 2000
    416
    Raffi,
    One other thought for you. If you're inclined to move to an amp for purposes of 2 chn music, then a 2 chn amp is probably just what you need. (lots of options here, and some particularly good used deals--check Audiogon)
    If, however, you listen mostly to multi-channel formats then you might consider a 3chn amp--something to maintain a similar sonic signature across your mains and your center.
    Mike
  10. Jeremy Hegna
    Jeremy Hegna Supporting Actor
    Nov 28, 2000
    812
    I'm having a great time with my Rotel 1090. It's a beast of an amplifier, the 1080 is good as well. I auditioned that in the beginning.
    Alot of folks on the forum are having good luck with the Paradigm/Parasound combo. The 2205 will fit nicely into your budget. You can bi-amp your mains (440w/2) and run the extra channel to your center. You could also do this with the Rotel 1095.
    Jer
  11. Doug_B
    Doug_B Screenwriter
    Feb 11, 2001
    1,081
    As an owner of both the 2 and 3 channel Stratos, I would not hesitate to recommend either one, with cap upgrade. With respect to the 3 channel, I don't see any issue with it driving your front 3 speakers for either HT or multichannel music; there should be no compromises versus the 2 channel version.
    The point made about your B&K being up to the task is also well taken, as I agree that the 60's are not very demanding to drive. I am not familiar with the 305 (may have heard it once or twice while auditioning speakers), but it may be wise to look into auditioning your 60's with an amp in your price range to see whether it's worth the upgrade for you.
    Doug
