wall plates, connectors and junction boxes (1 Viewer)
Jim Ed
I am trying to clean up my home theater area, for the wife.... I have 9 sets of 12 gauge home depot speaker wire coming out of a 2 gang box. I have look in the parts express catalog, but I do not see anything that would seem to take such a large gauge cable. Does anyone have any links? or suggestions...
MikeWh
Here's some "partial help"--
Leviton makes a line of "QuickPort" connectors and modularized gang plates. (Similar systems, if not Leviton, can be found in Home Depot/Lowes). Their biggest dual gang that I saw accomodates SIX pairs of wires (they call it a "12-port". I don't know if you'll find something else that will work for 9 pairs....
I bought a modularized system (says "Pass & Seymour" on the back of the plate), after I ran into the same problem with binders on another type of plate not being big enough for my wire. Turns out the modularized ones weren't big enough either, so I just soldered my wires to the screw-type binding posts on the back of the banana-plug module.
I can't find specs on the wire gauge that the Leviton QuickPort posts will take. Here is a product catalog. http://www.leviton.com/pdfs/d-503/d-503s.pdf
See p. 3 of 62 for connectors.
See p. 8 of 62 for the plates.
According to the catalog, customer service is 800-722-2082. I'd call them to ask about gauge.
Here's another system that looks like it'll take EIGHT pairs (2x4 pairs for dual gang)
http://www.crutchfield.com/cgi-bin/S...=0&cc=01&avf=N
I'm thinking that your best bet is to add a post-construction single-gang box right next to your dual, and then pull a couple pairs over to it.
Neil Hodge
I have QuickPort hardware throughout my house. It's quite slick; very easy to use. I am going to get some more shortly to clean up my speaker wire.
Neil
AaronJW
i bought some of the leviton items mentioned above from smarthome.com and have been very pleased with them.
Neil Hodge
Most professional (read "contractor") electrical supply houses should carry this stuff too; that is where I get mine.
Neil
Jesse P
Grip
I used 12GA wire and found a nice plate with binding post that will handel it at Radio Shack, I'm not sure if they have a 2 gang box, The one I have has post for 4 pairs, I don't run my fronts or center channel through it.
On another note, for the termination at the speaker I just bought blank plates and drilled a hole in it, put a rubber strain relief on it and ran my wire staight to the speaker. That might be something to consider doing on the receiver end.
Good luck.
Jim Ed
wow...thanks for the quick replys....just got off of the phone with levitron, and they will accept up to 14 gauge... what a bummer... I am going to call crutchfield next.
thanks
Drew Eckhardt
1. Parts Express has mounts for up to 4 pair of binding posts in one Decora insert, which would give you 8 pair in a double gang box. I have no idea what you'd do for more.
2. If the posts won't accept 12 gauge, you can always cut some strands. For the 1/4" of exposed wire, it won't make a difference.
Rich Stone
Mike,
The Radio Shack link looks EXACTLY like the Leviton Quickports I bought yesterday at Home Depot. It certainly looks like they should accept 12 gauge wire - my wire arrived today so when I get home I'll try the 12 gauge with the quickports.
BTW, the Radio Shack version is a couple of bucks cheaper that the Levitons. Not sure if there is a quality difference - might have to check it out.
Rich
Alfonso_M
I just terminated my surrounds wallplates using Leviton's Quick port jacks from HD, I used 12 AWG Recoton speaker cable without any problems.
Rich Stone
I'll confirm Alfonso's finding - the Leviton Quickports work with 12 gauge wire. I tried it out last night with Monster 2RCL 12 gauge in-wall wire and there was room to spare.
Rich
Jim Ed
Thanks again for all the suggestions.... I did a retro-fit last night. I put in a 4 gang box and hooked up the front sound stage. I went with the Niles Decora plate that holes up to 4 pair. Now I just need to find something to terminate my video, and the TV area will be done. I am going to use the levitron products for that area. I will post some pics, as soon as I finsh everything up this weekend.
Jim Ed
The rear surrounds are done, leaving me the hardest part left to do. The rack. I am going to be building an elfa rack this weekend, and running all of the cabling hopefully before Easter.
Staff online
AlinHobbs
