Wall Mounting JBL N24
Discussion in 'Speakers & Subwoofers' started by harold_s, Jun 30, 2003.
  1. harold_s
    harold_s Auditioning
    Jun 3, 2003
    6
    I'm looking at mounting the N24's that came in my NSP1 package, and I want to make sure I do it right. Does any one have any experience with mounting these speakers on Drywall? What type of screws/anchors or additional equipment did you use? Thanks.
  2. Phil Iturralde
    Phil Iturralde Screenwriter
    Oct 7, 1998
    1,867
    Use #6 or #8 molley bolts (insert and screw - Home Depot) .
    1) Pre-drill the holes (just large enough to start the insert) @ your chosen location
    .... a) Use the N24 wall bracket as a guide - level it first
    2) Use a hammer to tap-in the inserts
    3) Pre-screw-in the screw to expand the insert behind the wall.
    4) Take out the screws and install the N24 omni-mount bracket.
    Phil
  3. harold_s
    Jun 3, 2003
    6
    Thanks for the reply and info. So would you say it is a difficult install? I'm doing a 7.1 install and all the surround speakers will be about 7' feet up(any opinions on the placement are greatly appreciated as well). Looks like I have my work cut out for me.
  4. Phil Iturralde
    Oct 7, 1998
    1,867
  5. harold_s
    Jun 3, 2003
    6
    Man I wouldn't mind having all the space that you have. I think that my room is a about 12x14(maybe alittle bigger) with 8 foot ceilings, but hopefully this will do. The 7' measurement I gave was were I am putting the mounts, so from the bottom of the speaker it should be just over 6.5'. Thanks again for the help.
  6. Phil Iturralde
    Oct 7, 1998
    1,867
  7. David_Stein
    David_Stein Second Unit
    Feb 13, 2002
    422
    i didnt even bother with the inserts, i just screwed the screws right into the drywall and they were solid.
  8. harold_s
    Jun 3, 2003
    6
    so you got the screws that came with anchors and you only put the screws in the dry wall only? And it holds up? Seemed kinda risky to me. How long has it been up?
