Wall Mounting Floor standing speakers?
Discussion in 'Speakers' started by Johan Meyer, Aug 17, 2003.
  1. Johan Meyer
    Johan Meyer Auditioning
    Jul 23, 2003
    12
    Due to space constraints in my Lounge I would like to wall mount my towers to free up space around the Floor area.
    My question is will I loose/Gain wrt the sound quality placing them higher and closer against the wall?
    I have lifted them temporaly and could hear a marked improvement in sound?
    I have the Wharfedale Valdus 400
    Also speaker stands are not an option as they will not help with the space problems I have?
    I have found some very sturdy brackets so I know the speakers will not fall down
    Johan
  2. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    I don't know how much they weigh, but unless you hit a stud I don't think the drywall will hold them, especially with the vibrations. And the studs might not be in ideal places.
    As far as sound goes, that is your judgement. I would assume that you would lose bass response. Also, if the tweeter gets too high you will lose your imaging.
