Wall Mounting Bracket Advice
Discussion in 'Archived Threads 2001-2004' started by BradyB, Sep 22, 2001.
  1. BradyB
    BradyB Stunt Coordinator
    Dec 17, 2000
    82
    Hi all,
    I just picked up some Energy take 5's for my home theater, and I was wondering what the best wall mounting bracket would be for these speakers. I would rather not drill into the speakers. Any help is appreciated.
    Cheers.
  2. DavidMich
    DavidMich Stunt Coordinator
    Nov 27, 2000
    177
    Check out this link. http://www.pinpoint-mktg.com/bt77.html
    I bought these and wa very impressed with the build quality of them. They are fairly inexpensive, and do a great job.
    They will actually hold much more weight than they state. I have actually "hung" off of them myself (185lbs.) and they didn't budge.
    You won't be disappointed....!
    The choices we make define our lives, because choice, not chance, determines destiny.
  3. Arthur Legardo
    Arthur Legardo Second Unit
    Jul 21, 1999
    441
    I picked up a pair of Pivotelli Coral speaker brackets a while back. They hold my Paradigm Atoms quite well and they can be titled or swivelled. However, I believe the Energy speakers are a little smaller than my Atoms so you may want to try their Rhodium speaker brackets.
