Wall mounting bookshelves question
Discussion in 'Speakers & Subwoofers' started by Michael__M, Feb 12, 2004.
  1. Michael__M
    Michael__M Stunt Coordinator
    Jan 12, 2004
    167
    I have rearranged my room and now will need to mount my Infinity IL10's up on the wall. What is the best way to do this? Should I build a small shelf or use universal mounts? Thanks again for all your help.
  2. Kevin G.
    Kevin G. Second Unit
    Sep 30, 2003
    403
    What weight?
    Are you OK with drilling holes in your speakers?
    Clamping style ?
  3. Michael__M
    Jan 12, 2004
    167
    Weight is 18lbs each. I guess I'm ok with drilling holes if you guys say it is ok.
  4. Kevin G.
    Sep 30, 2003
    403
    check these outhttp://www.crutchfield.com/cgi-bin/S-AhgieVOXeGI/ProdView.asp?s=0&c=1&g=110700&I=121BT1&o=m&a=0&cc=01&avf=N
    just got them last week for mine, the only disappointing thing is that they're made out of plastic.
    (and you do need to drill). So far they've held. also looked at thesehttp://www.crutchfield.com/cgi-bin/S-AhgieVOXeGI/ProdView.asp?s=0&c=1&g=110700&I=121BT77S&o=m&a=0&cc=01&avf=N
    Kinda expensive, PE also has some nice Vogel clamping style.http://www.partsexpress.com/pe/showdetl.cfm?&User_ID=17920837&St=3835&St2=-39460811&St3=82170187&DS_ID=3&Product_ID=15077&DID=7
  5. ThomasEdison
    ThomasEdison Extra
    Aug 15, 2003
    23
    Don't know if you were planning on putting them in the corners but I bought small corner shelves from Home Depot for about $7 a piece and they work and look great. They have a few different sizes. My rears are Infinity Entra Point Fives.
  6. Mike^C
    Mike^C Stunt Coordinator
    Dec 3, 2003
    74
    Mike
    I just mounted some 25 lb each, fairly deep Rocket RS150s with these sweet mounts.
    BT77
    They have a side clamping mechanism thats secured with bolts. Very nice and you dont have to drill. Crutchfield also has em. Take a look for yourself.
  7. Chris Quinn
    Chris Quinn Screenwriter
    Jan 12, 2003
    1,127
    Michael-
    I've got a pair of Omnimounts Series 20 for walls I can run by for you to play with. I got them at cost and will do the same for you if you want them. link. Just give me a PM.
    Chris Quinn
  8. DavidNighorn
    DavidNighorn Stunt Coordinator
    Jun 3, 2003
    112
    hometheaterdirect sells some very capable wall-mount brackets as well.
    David
  9. BrianMe
    BrianMe Stunt Coordinator
    Jun 9, 2003
    106
    Do you have a picture of these installed?
  10. Chris Fleming
    Oct 28, 2004
    38
    I have to ask about how wall mounting affects sound quality. Isn't it typically necessary to have ample space behind your speakers to achieve the best sound? Especially with rear-ported models? I'm just curious, because I've been leary of using wall mounts, but if everyone agrees that the negative effects on sound quality are minimal, I'd jump right in!
    Thanks!
  11. Norris
    Norris Stunt Coordinator
    Jul 14, 2002
    201
    I bought a pair of Omnimounts yesterday from good guys at $40 each ($80 total!!!). Looked at them at home, didn't like what I saw. First off, they're way too expensive. Secondly, that section of my wall has no stud, I'll have to go with toggle bolts for the drywall anchor. I think it's much safer to have a shelf to rest my Energy C3's (17 lbs)on than using the single 3/8 bolt to mount the speakers (unless you have a stud of course).
  12. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    Chris,
    Typically they aren’t mounted right up against the wall. Most mounting brackets will have them out a few inches, especially if the brackets have the capacity to angle them. The same would hold true if you’re using small shelves – you can get them away from the wall a little if needed.
    But you might not want to. Small speakers typically have minimal bass response, and mounting them as close to the wall as possible will give you some reinforcement there.
    Wayne A. Pflughaupt
  13. BrianMe
    Jun 9, 2003
    106
    Don't use a toggle bolt. Look at your local home store for some different drywall anchors. They make ones that will hold up to 75lbs without a stud. I have used them on all kinds of stuff.
  14. Norris
    Jul 14, 2002
    201
    Thanks for the advice. But I returned them already. Instead I bought 4 pieces of stylized wrought-iron 90 degree shelf support. However, I'm not gonna put up a shelf, just the 2 support, with the speaker resting on top.
