Rick Radford
- May 12, 2001
Currently, my surrounds are on 26" stands. One is in a 4 ft wide opening into another room.. and my 2 year old knocked it over the other day. (just cosmetic damage).
I'm considering putting them up on the wall (where they probably should have been anyway), and would appreciate some good recommendations for a decent wall mount that passes WAF. My surrounds are in the 10-15 lb weight category. They measure 13.5 x 8.5 x 8.5.
One concern would be about head strikes since this is a walkway into another area of the house. :-/
I would like to be able to angle them in and down, since they are direct radiating speakers. And I'd prefer not to have to put screws into the MDF, but will if necessary.
Should I just leave them on stands or do I have some good options for a wall mount scenario?
(The main reason I got DR speakers was due to the open area that one of them would have to be located in. The other is in a corner. I'm pleased with how they work, but admit to being curious as to how bi/dipoles would sound in my environment.)
