Wall connections
uforia
Grip
Marc
I am planning to install some wall plates on a new wall for my home theatre system. They would include:
one RCA for subwoofer
2 speaker connections
tv aerial
I have just found a wall plate that can fit all these connection in one, I was just wondering if there will be any sort of interference with the above connections on the same wall plate or its fine if wired up properly?
ChrisWiggles
It should be okay, though the speaker lines are amplified, so make sure you're using good shielded cable for the sub and antenna run. Test things before you finalize everything to make sure you're not getting any interference, but I wouldn't expect it to be a problem.
Georgiastevenson
