Doug_B
- Feb 11, 2001
To all you Maggie owners out there. I have a few questions concerning their line, as I may choose to audition them as part of purchasing a new audio/HT system (there is one Maggie dealer in NJ). First, here are some specifics of my situation.
Room size: 13x20x8, with equipment on short wall.
Percentage of Use: Music/HT would be at least 50/50, possibly a bit more towards music in terms of time spent.
Equipment: All audio equipment will be new (with exception of existing DVD player). I will likely try out Odyssey Stratos 2 and 3 channel amps, Outlaw pre/pro (if they come through), and SVS CS-Ultra sub. Speakers will be a 5 channel setup; no 7.1 in plans.
Questions:
- How do the Maggie MG 3.6s, MG 1.6s, and MG 12s compare in terms of sound, if used as mains? Note that the 3.6s may be beyond my budget, but if convinced,... How much breathing room do they need behind them? Can there be obstructions behind them, such as an SVS sub or part of an equipment rack? Do they need breathing room from the side walls? I am concerned that their width is too big, esp the 3.6s, given the 13' wall and the room needed for other stuff (maybe 5' wide RPTV in the future, an equipment rack, the SVS, etc.).
- What would one use for a center speaker? The MGCC1 is earmarked as such, but its freq response is documented on the web site to go down only to 160Hz.
- What would be good for the surrounds? I doubt that floorstanders can work in my room due to the need for space off the wall (whether due to the sound or even for the length of the legs), unless there are lower models that don't need as much room (MMGs?). In any case, wall-mounted side surrounds would be preferable. How are the MGMC1s as surrounds?
- How stable are the various floorstanders? I have kids, and even though the room will be locked, ...
- Is there typically a long wait to receive them once ordered? I would be interested in black all around.
Thanks.
Doug
"Today is a good day to die." ...Old Lodge Skins
Questions:
Thanks.
Doug
