w7 box size?
Discussion in 'Speakers & Subwoofers' started by Wade$K, Jan 28, 2006.
  1. Wade$K
    Wade$K Auditioning
    Dec 9, 2005
    7
    I built a 2.8 cu ft sealed box to use with my HT system and it doesn't sound right. Not very loud. Amp is a Behringer 2500. So its getting plenty of power. The xover is a behringer ultradrive 2496.
    I have no clue on what size to make the new box. This box for sure isn't right because the sub doesn't get loud, or sound good. Sub isn't blown and works fine just doesn't get deep etc like a 13" w7 does.
    Please help
    Thanks.
  2. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,310
    62
    9,110
    Mississippi
    Model the sub in WinISD or Unibox. Just enter the T/S parameters and adjust the enclosure size and tuning until you get a frequency response that is acceptable. Don't know what is acceptable? Make sure you model your current setup and use it as a baseline.
    -Robert
