Vtech 2430 cordless phone?
Discussion in 'Archived Threads 2001-2004' started by Allan, Feb 28, 2002.
  1. Allan
    Allan Stunt Coordinator
    Oct 1, 2000
    205
    Does anyone use this phone? I jsut bought (unfortunately off of Ebay and thus can't return it). Anyway, the reception on it is horrible. It is a 2.4 Ghz (or whaterver tht is) phone. It is so staticy (even if you are within 2 feet of the base). My old phone (a 900 Mhz ATT) was crystal clear. Is there anything I can do to fix the problem? Is this inherent in this model or did I get a lemon?
    thanks
    Allan
  2. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    Sounds like you got a lemon. Note that Vtech phones are crappy in general. I had a Sony 900MHz phone made by Vtech and the thing was a piece of junk. It never worked right.
    I've had a Casio 900 mhz DSS phone for the past 3 years and it's been great. I'd avoid Vtech and Sony like the plague for phones.
    KJP
  3. Don Black
    Don Black Screenwriter
    Dec 11, 1998
    1,480
    Staples was clearing out 2431s about 2 months ago for $39.99. I picked up 3 of them. They all work great.
