laforze
- Mar 31, 2017
- Derek
Good morning Gentlemen. New to the forum and am hoping you can help. I did a search first, but didn't seem to find any answers to my problem.
Firstly, I bought the VSX-90 back in Nov of 2015. Everything was working fine. Hoooked up my LG 60" along with the following:
Xbox 360
Xbox one
Digital Cable box
HTPC
After initial installation, everything worked just fine for at least a year. Then, one day i noticed i was getting no signal from one of the devices and was lazy, so i just swapped to another port. This worked and I called it a day. Thinking that something was wonky temporarily, I thought nothing of it.
I moved out of the apt and put the unit in storage for a few months and forgot about everything. Moved into my new place and now when i hook up almost everything identical to the list above, it seems that 2 of the 6 ports work.
Am i to assume that this is a hardware issue, or if any of the ports work, there should be no reason the other ports don't work? I've tried swapping out the different devices to the known working ports and they work fine. I just updated the firmware to the latest and still no go.
Before I take it in to have it repaired, I thought i'd reach out here an
Xbox 360
Xbox one
Digital Cable box
HTPC
