John H
- Nov 27, 1998
I am going to be using it only as a pre/pro with external amplification on all 7 channels.
The unit will be housed in an Elite component cabinet on the top fixed shelf. There will be 2" of clearance above the unit with 2½" on each side. The back is completely cut out and there is a glass door on front.
Will this be adequate air space for pre/pro use only?
